Fuel Management gauge installation guide
Hi, Can someone please email the installation instructions as well. I have installed the system, however I think the sender may be faulty. It seems to restrict the fuel to the motor after about 5 minutes of running. It is installed after the filter and before the primer bulb, but the primer cannot suck the fuel up to the motor with the sender installed. When I take the sender out it works fine.
I was able to blow through the uni, and it looks clean and doesn't seem to have any instructions. I will try and test it with power on again, but I would think that these things should fail safe and let fuel through in any case.
Any suggestions?
My email address is hawins013@bigpond.com
Copy of Wiring Diagram Please
Hi, could you send me a copy of the wiring diagram for my digital fuel gauge. I can't figure out which wire to connect my sending unit to or if i have to have a special sending unit for the digital gauge to work.
Peeyow@yahoo.com
Craig
I would love to get a copy of the Fuel Management installation guide! Attempting to hook up an older 200 carb'd motor. Thanks!
Send to: willxfs@yahoo.com
Which wires are needed.
Hi I would like to know which wires are need for a single motor. I see the red,black and the one for GPS (white). But have a question on the Green, ((green/white (Not used)) and the Yellow and Blue. Any help on these wires?
The green/wht you wont use the rest of them connect as in installation on my last post, connect to gauge harness from key switch, green to green, yellow to yellow, black to black, red to red and blue to blue.
