Fuel Management gauge installation guide
  • #31
    I have a 2008 F90TLR need information on wiring harnesses to connect multifunction gauge and fuel management gauge. I have the 10 pin main harness installed but think I need another harness for oil pressure and engine temperature alarms and trim position to connect to conectors on back of multifunction gauge. Also installing fuel management gauge, please send me a copy of the installation guide with harnesses part numbers and sender part numbers to jd1king1@q.com.
    Thanks,
    Jim
    • #32
      Fuel Mangement Gauge
      CAN I GET A COPY OF THE FUEL GAUGE
      MY E-MAIL IS GSHAKEDOWN@AOL.COM
      THANK
      • #33
        Need Manual
        Can you send me the manual for the gauges. I have not been able to find and I have been working on the Yamaha all day.
        My e-mail address is: aafaraldo@msn.com
        • #34
          me too please
          tzaris@gmail.com
          • #35
            Can you send me @ bigdaddy0969@yahoo.com
            • #36
              One More
              Please send me the manual also. I just purchased a 2800WA Pro Sports Cat with Twin 200 HPDIs. The Fuel Management Gauge is unreadable
              doug.morgan@insight.com
              • #37
                You will be a life saver if I can get a copy. Thanks in advance.
                butlerc6@nationwide.com
                • #38
                  May I please also have a copy of the same wiring diagram/installation instructions? Please send to nicholasribich@hotmail.com. Many thanks in advance.
                  • #39
                    yamaha gauges
                    could you please send me the installation manual for command link guages.
                    thanks
                    tser2003@yahoo.ca
                    • #40
                      Could you also email me one as well?
                      thanks again!
                      Rlbol@aol.com
                      • #41
                        Copy of the guide as well
                        Would you be so kind to send me a copy of the wiring guide as well?
                        blaruffa@hotmail.com
                        It would be most appreciated
                        • #42
                          Which Pin?
                          On my FMM on the PS2 style connector, I don't have the additional wire that takes that down to the single white wire.
                          I was wondering if it is possible to buy like a S-VHS extension cable to plug that plug from FMM into and then cut the SVHS cable to do the final connection to GPS. Any thoughts on this?
                          • #43
                            No it will connect to GPS using the NMEA 0183 lead on GPS.
                            • #44
                              My fuel management system for 2002 twin F115's on a boat I just bought doesn't display speed. Wiring diagram would be appreciated to pipertwin@sbcglobal.net. Any thoughts on what to check first? Boat has Furuno GPS Navnet system.
                              • #45
                                Me too please
                                Need for 2002 F225 Fuel Management . deptrai@dslextreme.com
