Fuel Management gauge installation guide
  • #61
    MaY I get a copy also please??
    TCampie@yahoo.com
    • #62
      Could you send me a copy also. Thanks
      ktugboat42@yahoo.com
      Pete
      • #63
        Hi, Can someone please email the installation instructions as well. I have installed the system, however I think the sender may be faulty. It seems to restrict the fuel to the motor after about 5 minutes of running. It is installed after the filter and before the primer bulb, but the primer cannot suck the fuel up to the motor with the sender installed. When I take the sender out it works fine.
        I was able to blow through the uni, and it looks clean and doesn't seem to have any instructions. I will try and test it with power on again, but I would think that these things should fail safe and let fuel through in any case.
        Any suggestions?
        My email address is hawins013@bigpond.com
        Last edited by hawkinsb; 04-05-2011, 06:12 PM. Reason: forgot to include email address
        • #64
          hi,
          could someone send me a copy of the instructions to aleaosk@verslo.is
          thanks,
          • #65
            Here is installation guide
            Yamaha FM Gauge.pdf
            • #66
              Yamaha Fuel Management Manual
              I'd appreciate it if you could send me a copy of the manual also.
              • #67
                Copy of Wiring Diagram Please
                Hi, could you send me a copy of the wiring diagram for my digital fuel gauge. I can't figure out which wire to connect my sending unit to or if i have to have a special sending unit for the digital gauge to work.
                Peeyow@yahoo.com
                Craig
                • #68
                  Can I get a copy of the install instructions emailed to joehydro_stl@yahoo.com? thanx
                  • #69
                    I would love to get a copy of the Fuel Management installation guide! Attempting to hook up an older 200 carb'd motor. Thanks!
                    Send to: willxfs@yahoo.com
                    • #70
                      Yamaha FM Gauge.pdf, click to open
                      • #71
                        Which wires are needed.
                        Hi I would like to know which wires are need for a single motor. I see the red,black and the one for GPS (white). But have a question on the Green, ((green/white (Not used)) and the Yellow and Blue. Any help on these wires?
                        • #72
                          The green/wht you wont use the rest of them connect as in installation on my last post, connect to gauge harness from key switch, green to green, yellow to yellow, black to black, red to red and blue to blue.
                          • #73
                            I just want to thank you for your help. The unit is working just fine.
                            • #74
                              Also looking for an installation guide for fuel management gauge?
                              Thanks,
                              Josh. Joshrloya@gmail.com
                              • #75
                                Can I get a copy of the install instructions emailed im4219@aol.com
