I recently rebuilt half the carburetor and deep cleaned it, changed the fuel pump, the spark plugs, the fuel filter, the lower unit gear lube. And then did a seafoam hot soak. The engine is running much bethere now and my previous problems are all gone. But while running wide open I'm only getting to 4200 rpm. I have a four blade prop, which I understand lowers the max rpm but should it be this low? Any advice would be appreciated
Max rpms are only 4200 when wide open. 2001,115 yamaha
Did the motor go over those RPM before you "fixed it"? No idea what deep cleaning a carb is, but if you just washed it, or placed it in some sort of solvent, it is not cleaned.
I cleaned both double barrel carburetors. I just replaced half the parts inside, is what I meant..
It's a 17'8" Action craft with a 115 tlry 2001 YAMAHA.
Originally posted by ausnoelm View PostDid the motor go over those RPM before you "fixed it"? No idea what deep cleaning a carb is, but if you just washed it, or placed it in some sort of solvent, it is not cleaned.
I'm told it used to run at 5200 rpm 10 years ago
Still no info on prop being used.
Is this so hard to understand that we have no idea what you are running?
Here is something for you to look up a rig like yours to see what prop they used and what they got out of it
Outboard Performance, Performance Bulletins | Yamaha Outboards
does not take a mechanic to look at a prop or the web site link I posted to find a rig close to yours
The only numbers stamped into the prop are 8965 1 1/4 x 20 it looks like. The last number is difficult to make out, it could be 26..
I gather the boat / engine is new to you as it was quote:
"I'm told it used to run at 5200 rpm 10 years ago".
I don't see your engine ( 115 tlry 2001 YAMAHA ) in the US parts diagram here:
http://www.boats.net/parts/search/Ya...001/parts.html
I assume its a two stroke, V4?
.Last edited by TownsendsFJR1300; 07-30-2017, 07:19 PM.Scott
It's very hard to make out but it looks like 13 1/4 and the prop measures to 13 1/4 across..
Yes ivery had it for about a year. And sorry it's a 2000 115tlry 2 stroke
[QUOTE=TownsendsFJR1300;144452]I gather the boat / engine is new to you as it was quote:
2001 Yamaha Outboard Parts
There is a 2000 F115 TLRY? It appears to be FI. Could that be your engineDennis
ÂÂÂÂÂÂÂ
