Originally posted by TownsendsFJR1300
View Post
And no, there was no mention of in-between owners. But there was mentions of fuel filters, carb cleaning and draining etc etc....
Don't over complicate it.
When an outboard gets to the upper end of the RPM Curve, (4200 RPMs) but does not reach max recommended RPM; the prop is the most likely issue. Yes I am making an assumption, but it is an educated one.
If the engine would only rev to 2500 or 3500 then there would be other engine issues to potentially look into (is the tach set right would still be next before jumping into the engine). If it sputtered, surged, cut on and off, then yes. Explore the engine. But, he stated it's running "much better now" and at 4200 he's not that far out of spec. Re-prop, get the revs right and enjoy the boat.
If you hear hoof beats; think horses. Not zebras.
