2016 F70 with less than 70 hours. New boat to me. Starts and runs like a champ for an hour and shuts down. Let it sit for an hour and it starts/runs fine for another hour and shuts down again. The boat is 21 years old so I replaced the fuel line, pickup, bulb and added a Racor filter/ water separator for good measure. Any ideas?
2016 F70 Issues
Running that long before shutdown, and then needing an hour of cooldown before running properly again screams ignition to me. Sounds like a coil breaking down. Coils seem to be way better than they were 20 years ago but if that isn't the textbook definition of an ignition break down then I don't know what is.
Originally posted by F25Portable View PostRunning that long before shutdown, and then needing an hour of cooldown before running properly again screams ignition to me. Sounds like a coil breaking down. Coils seem to be way better than they were 20 years ago but if that isn't the textbook definition of an ignition break down then I don't know what is.
Originally posted by Tony Harper View Postwas RPM is it shutting down at ? low speed or high speed ? approx RPM when it shuts down may help diagnosis
does pumping the primer bulb help any?
Might be the VST runs low on fuel where the electric pump has no fuel to pump?
if the VST is full all the time, then I would make sure there is 12 v + to the pump when the problem happens.
I guess the ECU grounds the neg to make the pump to run when the ECU thinks the motor is running, so need to find out what is supposed to make it realize the motor is running to make sure that signal is thereLast edited by 99yam40; 04-12-2022, 09:38 AM.
I guess the ECU grounds the neg to make the pump to run when the ECU thinks the motor is running, so need to find out what is supposed to make it realize the motor is running to make sure that signal is thereLast edited by Gatorlizard; 04-12-2022, 07:36 PM.
ÂÂÂÂ
