I have seen that cup design before on Yam motors. With those vertical lines. Damn if I can remember what motor it was.
2004 f225 txrc
Originally posted by 99yam40 View PostGuess it threw you off when Rod said that motor did not come with WIF, it did me
But I did mention it and fairdeal said the harness was capable ,so it has a place to hook it up to but the ECU probably does not show it
a leaning experience for several of us
Originally posted by 99yam40 View PostSo I am guessing that the ECU was what was grounding the pink wire after allLast edited by rpambrun; 09-06-2018, 06:53 PM.
Originally posted by rpambrun View Post
I also found a small bolt missing on the input tubes on cylinder #3. I found the bolt when I first removed the power head, but did not realize where it had come from and have since lost it. I ordered that bolt also. The bolt screws in just after the section with the butterfly valve.
their purpose is to provide access for a vacuum gauge device, when syncing the throttle bodies.
If missing, the engine is for sure not going to be running "optimally" - but beyond that, I'd be guessing...
But I believe he did say that it was an option
did you order the $10 clear cup or the $150 cup with wire?
One of these?
Originally posted by pstephens46 View Post
Option? Not many options on these motors. Order a model and it is what it is. At least in 2004.
ÂÂÂÂÂÂÂ
