Originally posted by 99yam40
View Post
2004 f225 txrc
I ended up tweaking my sore shoulder, but managed to put a new battery in my multimeter and get back to this frustrating project.of trying to find the elusive grounding that causes the horn to blast away at start, but after two hours in the hot North Carolina sun, no progress made. I have not found any clues on the internet except to check the wiring, Even Yamaha CS had little to offer except check the wiring, Maybe it is not the pink wire out of pin #3 on the ecm. Maybe it's another wire. The 10 pin cable is in great shape. I'll just keep picking at it until I find it.
I spent a couple of hours out on the boat searching for that elusive grounded wire by isolating different sections. I did not find anything, but I did see something a little suspicious. The #4 pin at the ECM white wire for the emergency shutoff switch showed as grounded whether the lanyard on the switch was installed or not. I would think that the white wire would be grounded only when the lanyard was out.
Originally posted by rpambrun View PostI would think that the white wire would be grounded only when the lanyard was out.
the grounding is done at the helm, regardless of engine model
although exactly what the grounded wire affects at the engine
depends on the model: ECM or - something else.
(personally I don't care to understand anything other than EFI)
Originally posted by fairdeal View Postthe grounding is done at the helm, regardless of engine model
When i have problems like that i use a homemade key switch harness with a horn on it. That way you can tell if it is the boat or engine.
Originally posted by walleye1 View PostWhen i have problems like that i use a homemade key switch harness with a horn on it. That way you can tell if it is the boat or engine.
take the controls from a different rig and plug it into the 10 pin connector on the motor.
that will eliminate the harness to con*****er along with the con*****er
Originally posted by 99yam40 View Posttake the controls from a different rig and plug it into the 10 pin connector on the motor.
BINGO! Here is the culprit. I don't know how many times I was going to disconnect this on board filter after I cleaned it out last week, but no more buzzer. I think this is an aftermarket filter. The cup has a shredded wire out of the bottom that I don't think can be repaired. Does anyone know where I can get a replacement. I tried Boats.net and they could not find it in their system.
Thanks in advance.
well that should have been seen a long time ago, a filter with wires coming out of it should have caught your attention.
does the switch read closed with your ohm meter?
If the motor did not come with it, probably does not need it, makes you wonder what they hooked it up toLast edited by 99yam40; 09-06-2018, 01:41 PM.
Originally posted by 99yam40 View Postwell that should have been seen a long time ago, a filter with wires coming out of it should have caught your attention.
Guess it threw you off when Rod said that motor did not come with WIF, it did me
But I did mention it and fairdeal said the harness was capable ,so it has a place to hook it up to but the ECU probably does not show it
a leaning experience for several of us
ÂÂÂÂÂÂÂÂÂÂÂÂÂ
