I'm getting ready to order a WP kit (it's due), oil, etc. No overheat alarms, stream is getting a little weaker..
I did some research on the Pressure Control Valve (mines original, never pulled).
The PCV is basically for water pressure at idle correct?
(It'll idle all day on muffs-no alarms..)
Being the new style "mushroom head PCV" and the gasket are cheap enough, good idea to change it out just for S&G's? (it's now 11 years old)
Being I never had it apart, basically, just yank it, clean if necessary, put the new "mushroom" style back on the end and re-install, correct?
Thanks ahead of time..
