OK, don't laugh but - battled vapor lock after running down numerous other rabbit holes. Dealer wanter to install tech bulletin which included rerouting fuel lines and a charcoal filter etc. They say I missed the recall they did on the 02, 03, and 04 before they did a redesign on the motor. It would cost about $1500 and one of the mechanics mentioned it doesn't always solve the problem all the time. I decided its the buildup of high temps under the engine cowling and when fuels sits it vaporizes. My theory is winter blend fuel is the worst, but thats neither here nor there.
Solution - I installed a blower on a hose attached to the front of the cowling. This keeps a constant airflow through the cowling when stopped or at idle speed. I tend to just run it all the time. I have used it for a year now and it works great. When I try to not run it I end up back at lock - like when the Coast Guard pulled me over and I shut down the engine and blower. Downside is NOISE and small current draw. Upside is $75 and its fixed. I worried about cutting the hole and affecting resale but they were only going to give me a few thousand on trade in value. Maybe I should patent the design - someone told me the new Mercury 300 has a blower inside.
