I see. So the speculation here is that LP fuel pump pressure relief valve may not be opening when it should. As in it may be requiring more than 10PSI before the valve allows fuel through?
and/ or the VST pressure relief valve, which should also open at 10PSI, may not be opening and the pressure I. The VST doesn’t allow for fuel to enter?
thanks for the video reference. That helps a lot. Do you mind telling me how that gauge test demonstration is setup? I’ll need to go buy a gauge and small compressor I’m guessing..
