Steering tension adjustment
It is cable. I mistook the one part for a hydraulic component. So how does one tighten up loose steering. There isn’t okay in the wheel, the motor just turns so easily that u can’t take hand off for a second at slow speed without it going full to the stop and turning
Wonder if a motorcycle style steering damper could be designed to fit on steering arm on motor?….my VW rail buggy has a small hydraulic cylinder type steering damper up front…takes the play/shimmy out of steering…..seems like a reasonable idea for outboards….My old C90 Yamaha has very smooth/free steering that pretty well requires a hand on the wheel to prevent turns…
I had a steering box where it had a screw underneath on the bulkhead side of the steering box behind the wheel on or through the cover that held the steering to the dashboard. It had a friction pad that run on the steering shaft that you tightened or loosened to what you wanted.
Not a Yamaha product, didn’t think Yamaha made anything to do with push/pull cable systems at the steering end.
Â
