Originally posted by panasonic
View Post
2016 F70 Issues
Lots of the new folks take Yam the wrong way. He is black and white. An Electrician. Follow the steps or you may die. A matter of fact guy. He doesn’t intend to aggravate.
Originally posted by Gatorlizard View Post
I don't have to worry about losing the cowling in the river.. I can reproduce the issue at will in the driveway repeatedly. Not sure what I did to get the warning (Also remember, people on here are trying to help you.. be kind).
You asked in a previous post how to rig up a pressure gauge with the cowl on..Why do you need the cowl on if you can make the problem happen in the driveway? Does the cowl need to be on for it to start acting up?
Originally posted by 99yam40 View Postall I can say is prove it is not a problem before eliminating it as the problem.
you eliminate enough things it will lead you somewhere.
why would this problem only be there when the cowling in on?
I can only assume it is because the ambient temp under the cowling is causing something electrical to temporally fail. Think about this scenario.... My lawn mower runs for 5 minutes and shuts down. 5 minutes later it starts up and runs for another 5 minutes. Easy diagnosis.. It's the coil. I wish my issue was this easy to solve.
monitor it to see if that is the problem
what electrical are you thinking is the problem?
I have been experiencing the same problem with a 2011 F70 300hrs. I When the problem fist appeared the boat was running fine then total loss of power and surging. When it cooled down it would run normally. The problem was inconsistent it would happen, then it would be another 10 hrs before it would happen again. I took the boat to my trusted mechanic and he couldn't find any thing wrong. Originally I thought it was a fuel problem and tried a remote tank, no change. I have replaced everything from the fuel pickup in the tank to the VST pump. The problem has been getting worse, it shows now in 8 minutes of running. I purchased the computer diagnostic system from ebay. I had the motor running (cold) ran fine for 8 minutes, then it just shutoff. On the computer I noticed the TPS and Intake Pressure fluctuating wildly with the motor not running. I opened the throttle and the intake pressure changed but still moved wildly. I checked the harness voltage to the TPS and it's showing what the computer shows. My guess its the ECM, I have a call into the mechanic to get his input. Hpoefully he will call me today.
Originally posted by Double_A View PostI have been experiencing the same problem with a 2011 F70 300hrs. I When the problem fist appeared the boat was running fine then total loss of power and surging. When it cooled down it would run normally. The problem was inconsistent it would happen, then it would be another 10 hrs before it would happen again. I took the boat to my trusted mechanic and he couldn't find any thing wrong. Originally I thought it was a fuel problem and tried a remote tank, no change. I have replaced everything from the fuel pickup in the tank to the VST pump. The problem has been getting worse, it shows now in 8 minutes of running. I purchased the computer diagnostic system from ebay. I had the motor running (cold) ran fine for 8 minutes, then it just shutoff. On the computer I noticed the TPS and Intake Pressure fluctuating wildly with the motor not running. I opened the throttle and the intake pressure changed but still moved wildly. I checked the harness voltage to the TPS and it's showing what the computer shows. My guess its the ECM, I have a call into the mechanic to get his input. Hpoefully he will call me today.Last edited by Gatorlizard; 07-14-2022, 10:58 AM.
Â
