I have twin 70s. New to me. Just got boat. Used 72 hours run time..3 beeps in neutral. Swapped onboard fuel filter housings (sensor) and trouble stays with port engine. From what I have been reading, a ground to the blue and wht wire to the sensor (switch) is how the alarm is activated. Tomorrow I will check that wire to ground. Question is is there something on the engine that generates alarms? Is it some type of alarm con*****er? Is there somewhere I can see a schematic? O'yeah, thanks for letting join the forum.. Jack
F70 3 beeps
Originally posted by 99yam40 View Postno one but you know what model motors you have and what year they were manufactured
remote con*****ed motors have buzzers in the con*****ers
Maybe you can tell us when the 3 beeps happen.
just key on , or motor running.
does it keep repeating over and over
does it stop when you put in gear
or do you have to turn the key off to stop the beeping?
it was my understanding water in fuel filter quits alarming when put in gear. I am not sure on what models.
if that is what this is and you swapped the filters between the motors and it did not change, then maybe a wiring problem( shorted wire)
Originally posted by Jack1747 View Post
Sorry about that. I do know better. F70LA 6CJ L 1009504 I checked the blue/wht wire at the plug with my ohm meter and it is zero ohms to ground.
Â
