Originally posted by CatCam
View Post
Rectifier/Regulator/Chagre wire questions
most the older carbed 2.6L V6 motors used a two wire lighting coil.
about the same test, green to green/green white(sometimes) and then both greens to ground to check for a lead shorted.
the unused red lead that is a capped off bullet connector is for an aux battery(if the international models had it).
I cant open any of the pictures.
Can you see this one? These appear to be the two green lighting coil wires but they are terminated with one ring terminal. SM shows the two green wires being connected to the R/R above, on the opposite side of the black and red wires.Originally posted by rodbolt17 View Postmost the older carbed 2.6L V6 motors used a two wire lighting coil.
I don't know if its an optical delusion or not but it does appear they are tied together.
there should be a green and a green white going to the regulator. doesn't matter which terminal.
I don't know if the international motors used the AC signal for a tach signal. if so one terminal will have 2 green or green/white wires.
Hi, Thanks so much for taking the time to discuss this for me, I don't know where to start but basically one of the bullet connectors had come loose (or been opened and not closed properly), It was the one on the fuse!!!
So after putting that back together I had amps running through the battery, about 10 at 1500 rpm, is that normal, my car would be about 25amp if I am not mistaken? The problem is that was reving without gear and i hate to do that. However that said, before this was connected the amps were flat dead so it is obviously taking a charge, I would love to know what is considered a normal charge? Should I be interested in amps or volts? I'm so sorry for the stupid questions because I see alot of people refer to volts but I've always understood we want to see amps pushing through the battery?
Thanks & Regards
Christopher
I too also wondered what was going on there, 4 connectors but only three being used. The green is joined together and the 4th seems to be available?Originally posted by rodbolt17 View PostI don't know if its an optical delusion or not but it does appear they are tied together.
About the age of this motor, I think it's 4 years old unless I have been had. It is still sold new (my model) in Japan. I am obviously very happy to be corrected!Originally posted by rodbolt17 View Postmost the older carbed 2.6L V6 motors used a two wire lighting coil.
a carbed version of the 200 hasn't been avalible here in probly 10 yrs or better.
the version with 6 pulser coils even longer.
no carbed 2 strokes at all since jan 2010.
10 amps is about right.
that system,best I recall is only good for about 15-18 amps at WOT.
outboards
I know that there are motors sold "not for usa" have a 12v out for running lights only...The U.S.C.G. don't like for good reason....The first time I saw that sorta knocked me for a loop as a electrical guy (guru Lol) hope that little fact helps !!
