It is two floats per carb, one float per cyld. top carb handles #1 nd #2 cyld and so on. CHECK?
You posted flow testing a single carb that feeds TWO CYLINDERS after a cleaning.
Your mixing apples and oranges for some reason...
And yes, this particular engine (and many OTHERS), it's a SINGLE CARB, two barrels, with TWO separate float bowls and floats.
(Rochchesters made two barrel carbs with a single float, float bowl, same as a 4 BBL Quadrajet.. Hollys, 4 BBLs, two separate bowls and two separate bowls.).
Has nothing to do with flow, but absolutely agreed, the fuel flow, thru the carb nipple, should be cleaned and checked with any cleaning.
*As we're mixing apples and oranges, here's a2 barrel carb, ONE FLOAT, ONE float bowl, for a TWIN cylinder, "V" KOHLER 18 HP engine:
(Notice the float stuck OPEN while the carb is upside down-one of two issues fixed)
Sorry to interrupt the flow testing convo (which actually is kinda interesting)
but it yes I obviously didn’t clean it out properly. I misread a post about “don’t bother removing the screws on the top.” Or the “SS plate” somewhere and didn’t have a manual at the time so I didn’t do it. Excuses excuses.
Rebuilt the carbs less than a month ago (and they needed it!) and i did notice that when i was turning in the screws to check the setting originally, some were almost 2 turns out.
And thank you for the advice on turning them out as opposed to in. I wasn't sure which direction to correct a lean condition. i should be able to check that at some point next week. So we shall see!
Thanks again.
I would revisit your carbs again, as you said they were in "need" of cleaning. I assume that they were quite dirty?
Very easy to miss a passage or an orifice on the first cleaning. You need to take them completely apart and make sure they are squeaky clean.
Compressed air is your friend whIle doing this and some fine copper wire strands to poke thru all the passage ways
Once you get them clean and back on do the link and sync and start your adjustments from there.
Keep at it....you will get it running right soon enough.
The thing is - the carb rebuild isn’t the annoying part - I enjoy engine work. It’s the 47 screws that hold on the air box that I hate taking out and putting back in.
i am curious where that picture of hooking up the hose to the carb fuel line is from. I’ve never ran water through fuel lines before Bessie’s just a finishing rinse in the sink.
Yep, I'll bite. When would you use two carbs on one cylinder?
Suzuki XF650 is a single cylinder motorcycle with TWO Mikuni carburettors.
Although not actual single cylinder, V8 engines can fit Edelbrock manifolds that can take two distinct (Holley) carbs , and they act as two supplying each cylinder together in turn.
As a direct answer, you may use two when one can't supply the CFM desired. But they are also used to increase low end torque, through better low airflow performance of smaller throats but added together still provide top end HP
But I think the argument centres around that there are multi barrel carburettors that act as multi carburettors with separate "supply's" (floats etc).and adjustments.
Suzuki XF650 is a single cylinder motorcycle with TWO Mikuni carburettors. I found that XF650 on-line, not sold in the US, but yes, you are correct..
Although not actual single cylinder, V8 engines can fit Edelbrock manifolds that can take two distinct (Holley) carbs , and they act as two supplying each cylinder together in turn. Not really. You have 8 barrels total(for an 8 cylinder engine. All the Edelbrock manifolds have an OPEN PLENUM OR an off set /"step" plenum. IE, each carb barrel is NOT directed into ONE cylinder only..
Agreed and more efficient than a single barrel, or one carb.
The older Suzuki 140 two strokes are FI'ed, however, they use ONE, large throttle body vs say my F150 with TWO, 2 barrel TB's..
I real man would use gasoline to flow test a carburetor instead of water. A bold man.
