Thanks for the help in advance.
OK guys, I can't get my F200 over 5000k
1. I have checked fuel pressure on the fly hooking up a fuel pressure gauge to the high pressure fuel rails while cruising at 5000 rpm's and I would get 42 to 44 psi continuous pressure in fuel.
2. fuel is fresh and I have added Sta-Bil Marine to my fuel at every fuel up.
3. fuel injectors have been cleaned and I clean all filters even the one in the VST.
4. I blow out the breather hose to fuel tank.
5. I connected the computer to the engine and it is all clear there too.
6. Idles and runs fine under 5000k
7. never replaced prop, cause it is the same one I have had on this boat since 2003 with no issue. This problem started in Nov 2017. use to be able to get up to 6000 rpm's before Nov, also hard to get into plane.
Any help would be appreciated.
