2 stroke yamaha 115 oil issue
For the proper orientation of the strainer onto the sender and the sender onto the tank. Easy is one thing. Correctly is another thing.Originally posted by Seacraft12 View PostWhat are the alignment marks for?? I literally just dropped it in the tank and put the sender in the middle of it. It went in that easy.
I would pull it back out and make sure that both are installed correctly. Just dropping it in might not get the job done. Maybe that is why you had the problem with the bent strainer.
The strainer goes on the sender first, snapping into place, and then the sender/strainer go into the tank with the triangles properly aligned with each other. Make sure the foam seal is installed on the strainer nipple.
We have a saying "after all else fails, follow directions".
It is a seal to keep oil from bypassing the strainer. Without the seal some oil would flow to the oil pump between the nipple at the bottom of the strainer and the oil tank.Originally posted by Seacraft12 View PostJust installed correctly. Thanks for all the help on this one. By the way what is the purpose of the foam piece on the bottom? Thanks
Seacraft12~
I recently went through replacing my strainer and thanks to the help from those on this forum I learned how crucial it is to install the strainer correctly. There are several little "nubs" (very small) on the top portion of the sensor and there are also corresponding holes in the top of the strainer and these must be aligned when assembled.
Also, I think it was Rodbolt that cautioned that the black foam washer at the bottom of the strainer must be installed properly, and make sure it doesn't fall in to the hole, which would interrupt the oil flow causing seizure of your engine.
Please let us know if you got your problem solved.
