Not sure what you mean by "inbetween the pos side of the reg out"
Manual for my C40 says to check output wires of regulator with all connected to check for peak voltage( regulator check) and if below spec connect to lighting coil wires while disconnected and check with peak voltmeter to see if in spec.( lighting coil check)
