I have a 2003 F115 fuel injected four stroke. My motor starts and idles perfectly, but will shut off or stutter when you go to throttle up even when not under a load. it gets better after it gets warmed up but still wants to skip some until about 7/8 throttle. then it smooths out completely. Even after being warmed up good it will skip causing the motor to jump intermittently at mid range throttle up to about 5200 RPM. I have new plugs and have tested fuel pressure I have around 46 psi when I turn the switch on and 38 psi when running. I did notice that fuel pressure spikes up about 8 psi when engine tries to stall. Engine usually takes about 2 secs to shut off after I turn key off, yesterday engine would not shut off, even after I pulled the kill switch. After about 2 mins it finally sputtered to a stop. after that it cranked with the kill switch out and then sputtered to a stop after about 8-10 secs. I let it set for a few mins and it started working fine again. I tested key switch and kill switch both seem ok..ground wire in harness OHMed out ok. I am starting to suspect my ECM..is there any way to test it without taking it to a dealer?? If I do take it to a dealer will it have trouble codes stored that will indicate my problem?? I think the stalling and the no shut off problems are coming from the same place, but I could be wrong. compression is 160 psi and appears to be good spark on all cylinders.
Thanks Sparkie
Thanks Sparkie
