well I am willing to invest some money into the proper tools..but if by very expensive you mean $1K or more, I just simply cannot do that right now. I will do the other test that I can do without it for now and see what I can find. The TPS is way low and needs to be adjusted properly. I printed off the instructions from my manual on how to set it. it said I need a test harness, but I assume I can just push my probes into the existing harness connector and test the voltage, I have done this on many other types of voltage checks. I will set TPS and will not use the computer but will use a digital volt meter. then I will check the 5v reference on each sensor. why would I measure the temp on top of the ISC?? maybe to see if it is not working properly and overloading the circuit?? Can I test the orange 5 volt reference with just the key on, or does motor have to be running??
If the manometer is to be used to set the throttle valve synchronization ,my manual shows it being done with a single vacuum gauge, which is way cheap. I am sure the 4 way thing is way better but if this will get the job done and save me big money...Remember I will be selling this motor as fast as I can once it is fixed.
