was not taken to be harsh at all. You have always been a big help and I greatly appreciate your input. It will be good for someone with my same problem to be able to find the end result. I thought about sending the injectors off..but at this point I know that there is something wrong with the electrical and I will get that fixed first. I do not know anything about a filter inside the pump..if there is one I am sure it would need to be cleaned..I am not sure why the fuel pressure is at 38 while running at all RPMs...when I just turn the key switch on without cranking it jumps to around 44-45. The factory manual I have says that key on fuel pressure should be appox. 44.1 and running it should be Apox. 35.6..so it seems to be right according to the manual.
By the way where are you catching all the fish at..I may drive down and bring my bass boat..LOL
