I guys: I have Yamaha 200 hp 1995,with new water pump,termos,presure valve and then continue overheating. I look for any obstruction in lower parts,and i can see any wrong. What i need to do.
200hp 1995 overheating
Did you get this issue solved. I havea 95 200 also that overheats at 2500 rpm. New pump thermos, poppet. Is scale build up that much of an overheat issue
recheck the water pump housing
I had a similar problem turns out the o-ring came unseated and a black rubber bushing that seals to the water tube was completely missing and not in the rebuild kit.
Originally posted by gonzofish View PostDid you get this issue solved. I havea 95 200 also that overheats at 2500 rpm. New pump thermos, poppet. Is scale build up that much of an overheat issue
Here's some interesting reading:
http://www.yamahaoutboardparts.com/f...g-th19434.html
http://www.yamahaoutboardparts.com/f...m-th23666.html
https://www.youtube.com/watch?v=ZJaTjMOEKP0 Flushing tips...Last edited by TownsendsFJR1300; 08-10-2014, 04:49 PM.Scott
ÂÂÂÂÂÂÂÂ
