1991 200 HP Yamaha OB
Checked with ohm meter wires on floats in remote and main tank. I found continuity as per troubleshooting guide. When I raise the main tank float halfway with key on the remote tank does not activate. It does pump using the emergency switch. Dash gauge shows the remote tank full and no alarms going off. The dash also shows trim is down full. The other engine pumps properly from its remote tank. What should I be looking for now?
