I have a 1991 TLRP 70hp and I change charging coils ( old coils burnt ) and rectifier regulator and now is charging at 17.0 volts at 4200 rpm. When I first start the engine it will charge at 13.50 volts and slowly goes to 17 volts. Is this normal or I got a bad rectifier. Thank you.
over charging?
over charging
I checked the battery terminals seems ok and cleaned them anyway. So I check the new rectifier from black wire to the 2 green wires and I have no continuity, should have low ohm reading according to the repair manual.
So I guess I'll get another rectifier.
overcharging
Check the output on the stator also! Stator could blow rectifier and coils, more expensive job but will blow out new rectifier if it is the stator!Originally posted by benyoung View PostI have a 1991 TLRP 70hp and I change charging coils ( old coils burnt ) and rectifier regulator and now is charging at 17.0 volts at 4200 rpm. When I first start the engine it will charge at 13.50 volts and slowly goes to 17 volts. Is this normal or I got a bad rectifier. Thank you.
