found that my gauges weren't working with my '92 70hp yamaha the other day. found the 10a fuse was blown but replacing this didnt help. there is a small box that looks like a relay but cant really tell. does anyone have any ideas? thanks
analogue gauges not working
Shouldn't be any relay for the gauges. Check that have 12 volts between yellow and black wires(with key on) at gauge. If don't check wiring and key switch, if do may be a bad gauge.
thanks for the reply.
i am only getting 2.3v at the yellow wire, but its running at 12.5amp and is getting quite hot. the oil full light is the only thing working. i have tacho fuel, trim and hour gauges.
is there anything else worth checking?
did a visual on the wiring around the motor and appears fine.
do you think there may be a fault somewhere between the motor and console?
Do you mean the Tach is getting hot, if so you have a bad tach. Not sure what you mean by running at 12.5 amps, there shouldn't be anything at console that would draw that much amperage.
that yellow wire that has the 12v for all the gauges is getting hot from the high current
yeah i know nothing should draw that many amps so a little curious why.
maybe i will have to take it in somewhere
can you tell me what that little black box that has the wires from the gauges going into it is?
Here is the basic wiring for Yamaha analog gauges.
ÂÂÂÂÂÂ
