When you use the time-sert is it recomended to remove the head or can you just install it?
Using a Time-Sert
I would think that if you installed with head on to repair stripped threads you would have to drill out the head far enough to let it clear and then the block to be able to thread,insert, and seat. Does not sound impossible I just do not know how much metal would have to be removed and how that would affect it.
Using A Time Sert
I tried to repair the thread myself with Sav A thread repair kit and heli coil but ended up cross threading the newly tapped hole. This is a 1990 Chevy Cavalier, so I am trying to determine if its worth trying a time sert.Attached Files[url=http://www.goarticles.com/cgi-bin/showa.cgi?C=2300082]Enhanced Kre-Alkalyn[/url]
[url=http://www.goarticles.com/cgi-bin/showa.cgi?C=2290126]ultimate acai max[/url]
Originally posted by robert graham View PostJust curious, but how is a time-cert different from a heli-coil?
++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
ÂÂÂ
