So far I've tried 2 1/2" impact wrenches one large air and 1 dewalt battery. Neither can get it as tight as I can with a 4' breaker bar. Once tight I heated with MAP gas for 10 mins, moving the torch around the center of flywheel. Still nothing. I can tell this puller I'm using with special grade 10.8 bolts is about to strip the center 3/4" bolt and is moving past vertical. I have hammered with w/ 6 lb sledge but I don't want to whack it anymore.
I'm about to give up and take it to a shop but I've allready bought the $125 belt.
What should I do?
What should I do?
