Good forum!
I am running twin 2008 F250B's. Motors have app. 650 hours on them. Running out the other day, heard a buzzing sound that it took me a second to identify as the warning alarm. Looked down, and OVERHEAT was scrolling across gauge on motor. I immediately pulled the throttle back, shut down the engine, trimmed up, and checked for obstructions. None found, so I tilted the motor down, removed the cowl, and found both heads to be hotter than normal(although I could still keep hands on for 3 to 4 seconds). Started engine, ran fine the rest of the day and for the next three days straight. I am thinking temporary blockage on lower unit pickups from a bag/weeds that fell off when I shut it down? Thoughts?
Also...would an overheat cause potential damage? Engine ran as good as always since then, from idle all the way to WOT of 6000RPMs.
Finally, I was surprised that the alarm wasn't louder. It took a couple of seconds to distinguish it as the alarm. I am guessing this is normal? Also, the alarm was on for a couple seconds before I pulled the throttle back...should the reduced RPM mode have kicked in before then, or did I pull the throttle back before it had a chance to engage?
Thanks in advance.
Thanks in advance.
