I have a 2004 T8PLRC I have rigged as a fully remotetely con*****ed kicker, and I have installed matching Teleflex analog gauges for it as well as for my 225 HP main. My problem is with the oil pressure sender. The sender that Teleflex sells is too large to fit under the cowling of the T8, even if I could find a place to install it at all, which seems apparently doubtful. I see from the parts catalog that there is an "oil pressure switch" that must operate the low oil light on the front of the motor (and alarm horn), and is apparently located under the flywheel.
1. My sense is that it (the pressure switch) probably won't effectively signal my analog oil pressure gauge. True??
2. If #1 is true, then I wonder if Yamaha makes or has access to a small sender that would signal my analog gauge, that I could replace the pressure switch with, and would still fit where the pressure switch is currently located??
