Yamaha 2004 50HP two stroke (model # 50TLRC)
Fluid is leaking from around the ram in the tilt-trim cylinder. I assume that one or more of the "O" rings and/or seals in the piston sub assembly need replacing. Is there a kit containing the necessary parts to rebuild the sub assembly or do I need to order the parts separately? There seem to be a lot of rings and seals in this assembly and I'm not sure which ones I would need.
Also, does anyone know what special tools would be required to do this job properly?
Thanks for any help.
