Hi,new to this forum and look forward to posting and helping out. I inherited a 2000 model f25elry . and it's a challenge for me to get it running. I bought a 703 con*****er and have so far fixed the starter. With plugs removed i had a mess of oil come out the plug hole. I think someone laid the motor down wrongly and filled the cylinder with oil . measured 120 psi compression on both. I can't get electric to work correctly. I jumped the starter to get it to turn over. I tried to measure voltage at the plugin and there is none. Shouldn't there be some/.? At this point i want to run it in a barrel. no joy.....The electric goes from the starter solenoid across to the relay board and there seems to die......How do you test for a relay board. and also are the computers prone to failing and how do you test them.....any help thanks
Rich
Rich
He splices a ring terminal onto it and attaches at the starter connection and Bingo! we have ignition......What an incredibly easy diagnoses. Now the motor has other issues which i'll address as time and money allow........
