Is 6K3-82557-00-00 a good number?
tiller to remote question
6K3-82557-00-00 is not a good number, not sure what it is.
If you look at this post, this is the number that you gave me...
http://www.yamahaoutboardparts.com/f...on-th7347.html
I found it, 6K3-82557-00-00 supersedes to 6G1-83557-00-00 it is plastic sleeve that covers the wires.
I have question about the wire harness.....When you connect the remote end and the motor end of the wire harnesses, is the final connection inside or outside of the motor cowling.....how are the wires run if the the connection is inside....do the parts that you listed above include parts that seal off the motor from water???????Attached FilesLast edited by dcc134; 07-22-2009, 07:56 AM.
what do I do?
On the 25 it normally has a couple feet of harness and control box harness connection is outside cowling.
Yamaha Tiller arm
Originally posted by dcc134 View PostI have a 25 hp elect start 07 yamaha on a carolina skiff. I want to change it to remote steering ...My motor is 25ESH ..serial 6L2K S 1024831....What parts do I need to make this conversion.....should I add engine gauges to the console?....I know that there is a steering bracket that attaches to motor that I can't find..Where do I get that bracket......I'm pretty handy...What tools do you need to make this change? ...I have a good Idea, but I want to make sure before I buy....would I need a Remote Conversion Kit?
Do you still have the tiller arm off the 2007 25 HP motor that you were converting to remeote steering>
Alan 970-470-3613
Do you still have the tiller arm for the 2007 Yamaha 25 that you were converting to remote steering.
Alan 970-470-3613
96 Conversion
Originally posted by boats.net View PostYou would need
6L2-48501-11-00 Remote attachment kit
689-61350-02-00 Steering guide attachment
6J8-48511-51-4D Steering Hook
703-48230-15-10 Control Box
order 2 control cables, MAR-CABLE-xx-SC(replace xx with length of cables needed)
For the key switch and choke to operate from control box you would need:
(1)6L2-42725-50-00
(1)6L2-86111-00-00
(1)682-86117-00-00
(1)6L2-86115-00-00
(1)98580-05008-00
(2)92990-05600-00
(1)90480-10155-00
(4)98508-04008-00
(4)92990-04200-00
(1)6L2-86112-00-00
(3)97013-06012-00
(3)92990-06100-00
(1)93210-03261-00
(1)6L2-82590-00-00
(1)6K3-82557-00-00
Originally posted by outdoorsman View PostWould these parts fit the 1996 25hp model?
ÂÂÂÂÂÂÂÂÂÂÂÂÂ
