As for the pin # the are all ready number on the VAG-COM, I got the USB KKL VAG-COM for 409.1 (Blue cable) and it has a red light wich it comes on when I turn the ignition switch on, my laptop has 3 USB port wich they seem to detect the VAG-COM cable, I am going to try again tomorrow, thank's for the info I will post Again when I get it right.
Yamaha Diagnostic Software - Where can i order it ?
Originally posted by loyoki View PostPerfect, $10 is in China or Hong Kong.
Simply connect OBDII cable with 3 wires to 3 pins (male) engine connector
Viewing engine plug:
[] GND(to 4)
TX(to 7)[] [] 12V(to 16)
When you switch on engine, cable led must light on, if not, invert TX and 12V.Last edited by davepjr71; 12-20-2011, 10:18 AM.
yds
maybe you guys shold stop messing about with the home made stuff!!
just found this guy who has YDS V1.33 & interface kit
www.brpdiagnostics.com
got mine and it works great
Originally posted by powersports View Postmaybe you guys shold stop messing about with the home made stuff!!
the homemade rig works, I was forced to do it because BRP had the cable on back order for 6 months, besides that they charge you hundreds of dollars for a $10 cable what a stinking rip off. I used version 1.30, windows XP, and I had to assign the usb port to "port 1". it worked great.
I have to agree with sparkie,why spend hundreds.There probably using the same kind of adapter with a yamaha sticker on it.By the way i have to thank the one who figured this out to use the vagcom .
I have a question for the poster of this info:
[] GND(to 4)
My male plug on the engine is orientated like this:
so would you directions be the same in my case:
[GND]
-----[12V]
[TX]
Thanks for any clarification on this.
- CraigAttached Files
Late reply to this thread but it may help others.
I ordered a $13 dollar cable off E-bay and it works fine.
Make sure it is ISO4191 compatible, that is the standard Mitsubishi / Yamaha used to make the ECU.
The USB version of the cable will install a "USB to serial" driver when it installs. On my computer it installed it and set the COM port to COM6. The Yamaha software could not find it and just errored out. If you follow the instructions above and can not get the connection to work follow these steps.
(XP computer)
Open your device manager
1. Click start, the choose run
2. In the prompt box type devmgmt.msc and press enter.
3. Find and expand the Ports list.
4. Select then right click the USB to serial port that represents your cable.
5. Select Properties
6. Click the tab on top for port settings
7. Click the advanced button.
8. Set the COM port to COM port 1.
After I made these changes it linked right up and the Yamaha software had no idea I was not using the Yamaha cable.
Hope this helps.
-Shane Spencer
Hello all. I am over from another boat forum which relies on yamahas exclusively.
I have the YDS software, but am trying to build a cable. I also happen to have an OBD cable that I got with a purchase of a scan tool for my car. In theory, this should work right? It came from scantool.net but I can't seem to get the YDS to recognize the cable.
I also just bought a new cable from ebay, but it would be great to be able to make this happen with what I have.
Thanks!
Originally posted by landandseaHello and did you manage to get the diagnostic kit for yamaha as i have some for sale! yamaha-diagnostic@hotmail.com1987 Pursuit 2200
2001 Yamaha SX225TXRZ, 1987 Yamaha 9.9 Kicker
ÂÂÂÂÂ
