....will my gauges from the 1989 plug and play?
Replace 1989 200 with 1995
The wire harness for trim sender and oil/overheat lights are different, the 95 has square connectors not the round. You would need 6R3-82541-10-00 and 6N7-82541-10-00 harness adapter's.
The only other harness besides 10 pin main and 2 gauge harness's is the oil tank harness. If you are using the 89 oil tank on a 95 motor then you would need 6R3-82541-00-00 adapter harness.
Yes 6R3-82541-00-00 is the oil tank harness adapter and -10-00 is the oil warning indicator wire adapter.
