Replace 1989 200 with 1995
  • Replace 1989 200 with 1995
    ....will my gauges from the 1989 plug and play?
    The wire harness for trim sender and oil/overheat lights are different, the 95 has square connectors not the round. You would need 6R3-82541-10-00 and 6N7-82541-10-00 harness adapter's.
      Are the connections at the engine the same?
      thanks
        Now I'm talking about the main engine harness connections....not gauges.
          Yes the 10 pin main harness is the same.
            What do I do about the other harness connectors under the cowl? They are different too. They sure don't make it easy!
              The only other harness besides 10 pin main and 2 gauge harness's is the oil tank harness. If you are using the 89 oil tank on a 95 motor then you would need 6R3-82541-00-00 adapter harness.
                Cool, thanks
                Are 6R3-82541-00-00 and 6R3-82541-10-00 for different purposes?
                  Yes 6R3-82541-00-00 is the oil tank harness adapter and -10-00 is the oil warning indicator wire adapter.
