Changed the Impeller today and I was pulling out the lower unit hard since it was stuck (did disconnect the speedo tube) suddenly it came off but the shift rod on the lower unit had the metal tube on it. I do remember that that tube used to be left on the upper part of the shift rod (not the LU) and were the lower unit shift stick needed to slide into. I can now manually slide the tube on the upper stick but it needs to be kept in place while installing the LU. Is this something that can be fixed or do I need parts and in that case what parts (the whole shift rod?)
Joe
Joe
