I have a 2005 115 two stroke with digital tach and speedo. The temperature indicator on the tach blinks all the time, even if the motor is not running. According to the manual this means the engine is overheating, but if it has not run for days how could this be? During operation there is a strong stream from the water passage and no leaks in the motor or shaft area. While running it never triggers the alarm or reduces rpm. I assume this has something to do with an incorrect dip switch setting or possibly a thermo switch.
Can anybody help?
Can anybody help?
