Performed maintenance to my 25hp 2 stroke Yamy over the weekend and have a couple questions for the gurus. Replaced the spark plugs but did not have a torque wrench. So, I tightened them 1/4 turn past finger tight. Is this adequate? The engine started so I am assuming it is. Also, I inspected the prop shaft and all was ok...however, when putting the prop back on I wasn't sure which way the thrust washer went back on. I put it on so that it fit firmly against the seal. How do you know which way is correct? In addition, is it normal for the prop not to easily slide back on? I had to knock it back into place with a block of wood and a hammer. I also screwed the prop nut back on a 1/4-1/2 turn past finger tight...is this adequate? Sorry for the novice questions but I am new to this. Thanks in advance!
prop and spark plug question
