hello
i am trying to figure what is wrong on my trim indicator on a c115 tlrt 1995.
behind the gage,12v and ground ok, only the pink and the black are connected from the trim indicator harness to the gage.
when i put ground on the pink, the gage goes all the way down, when not at ground, the gage goes all the way up and stuck.
i checked the trim sensor at the engine swivel, not stuck up, goes up and dwn easily.
checked the resistance with ohmmeter between pink and black , pink and orange and black and orange: nothing nowhere,the resistance never change, up or dwn position
is the trim sensor shot? i guess
also, i tried to remove it, philips screws are frozen solid in the bracket.
any tip? maybe breaking the plastic sensor and try to remove the screws with visegrip
any help will be apreciated
frenchy
frenchy
