had problems in the past with what I thought was a bad ground, disconnected batteries and cleaned them up, before that I would not get anything when I turned the key unless I jumped ground from battery to starter, after I cleaned up the connections, everything was fine, started the engine 7-8 times, with no problem, got home to flush, and nothing, not even a reading on the fuel gauge, or nothing from the trim switch on the remote, but the tilt switch on the engine worked fine. I wiggled the wires going into the starter, then I shifted the remote quickly, and now things are okay again (for now). where can I find a schematic for the key switch? I have a yamaha manual and the ignition is not in there. Would the neutral safety switch cut power from the trim and fuel gauge? Does anyone have any ideas?
thanks in advance
thanks in advance
