Have some questions regarding a Yamaha ProV 150. When I bought it the owner wasn't sure what the year was. He said either 85 or 86, (the number on the ID tag is 6J9 L 301 915). The motor has a stainless steel prop (3 blade) with "21-M" stamped on it, (assuming 21 equals pitch). Please help answering the following questions:
What year is the motor?
What is the proper pitch and diameter of prop?
What is the wide open throttle (WOT) range?
What do the 3 symbols/lights on the tachometer represent?
The left symbol is a circle that appears to be almost empty. The middle symbol is an oil can. The right hand symbol is a circle that appears to be almost full.
Occasionally an alarm sounds that is housed in the control box , (seems to happen when using trim/tilt). Please inform as to what the alarm means.
