How do I reset my hours clock on my Yamaha tach? I tried pushing the set button, tried holding down the set button, tried pushing the mode button and set button together, but it will not reset?
Yamaha Tach reset
The tach has only two buttons, one says "set" and the other says "mode" when I push the set button nothing happens (still displays hrs) when I push the mode button the hrs disappear and shows nothing. Tried pushing both together and also holding down the set, but hours don't re-set. Any thoughts?
Re Visit this post
I joined the forum to get the above questioned answered. So I am hoping someone has found the answer...Originally posted by baymaster View PostThe tach has only two buttons, one says "set" and the other says "mode" when I push the set button nothing happens (still displays hrs) when I push the mode button the hrs disappear and shows nothing. Tried pushing both together and also holding down the set, but hours don't re-set. Any thoughts?
Thanks,
The total run time(engine operating hours) can't be reset as Mike said only the trip meter which you have already zeroed out.
Sorry I was not clear. I have tried the above method and the trip time is still the same as the total run time. It does not want to zero out. I believe in the previous post's they had the same problem.Originally posted by boats.net View PostThe total run time(engine operating hours) can't be reset as Mike said only the trip meter which you have already zeroed out.
It is no big deal, but I think there should be a way.
