Purchased a 2006 18' Grady White CC in June. The boat is moored in a marina and because it takes ~12 hours to pick up the trailer, haul to the dealer, I want to take care of any preventative maintenance of known issues I may encounter.
When I bought the boat it had ~300 hours and ran fine, but shortly after developed a problem reaching WOT that turned out to be a bad ignition coil.
To date I have replaced the following items:
balancer
timing belt
ignition coil
drive shaft seal/o-ring
shift seal/o-ring
internal anodes
water pump
thermostat
VST filter
HP fuel pump (gift from dealer)
injectors
trim/tilt seals
1 scratched ram
o-rings between hydraulic pump and trim/tilt assembly
spark plugs
oil filter
engine oil
lower gear oil
propeller shaft seal
fuel/water separator filter
It's at the dealer now, anything else I should be doing?
Thanks for any suggestions.
balancer
timing belt
ignition coil
shift seal/o-ring
internal anodes
water pump
thermostat
VST filter
injectors
trim/tilt seals
1 scratched ram
spark plugs
oil filter
engine oil
lower gear oil
