2005 F90TLRD
Was driving my boat on plane today and as I trimmed the engine I noticed that it was not moving much. I came to a stop and tried trimming and eventually the engine stopped about half way up. Battery is brand new and good. I can hear the relays clicking when I try to trim up or down. I have never dealt with a trim problem, what should I check? I'm assuming I probably need a new trim motor.
When I got back to my dock, I loosened the manual trim screw on the port side and the enginen dropped all the way down. I then tried to lift the engine up while I was standing in the water, but I could barely move it and it was a struggle. Should it be this difficiult to manually move the engine to the up position? I'm not a weight lifter but I am not too weak either.
