I didn't tackle anything too difficult - but parts of it were frustrating. Just a general overhaul and maintenance of the cooling system. This is split up because the site doesn't allow for more than 4 images per post.
For what it's worth I've got a 2001 150 OX66 (SX150TXRZ)
Generally when I get a new engine I do all the "annual" stuff on my own regardless of when the previous owner said they did it. Only exception is if there is a shop reciept showing what was done.
So I started with all this:
Plugs
Thermostats and gaskets
New pressure relief
New anodes
New fuel filters
New waterpunp (all of it - housing, collars, gaskets and inpeller)
Started with the thermostats because they are frankly as easy as the spark plugs.
Remove the four bolts at the top of the port and starboard housings on the engine to reveal the stats and gaskets.
After you take out the stat do a good cleaning of the cover and the mounting surface. A soft bristled brush and some Yamalube Corrosiom Prorectsnt got the job done
Plugs
New pressure relief
New anodes
New fuel filters
