Hello all. I have gotten a lot of tip over the years from you guys, thank you.
I have had zero problems with my 03 225 HPDI until now. I pulled out my boat(skeeter zx225) this weekend and did my spring checks. I am getting zero gas to the engine. The low pressure pumps are dry and the primer ball is soft and will not pump up. I drained the starboard tank last fall and the port tank had about 1/2 in it with stabilizer.
Where should I start. I do not see or hear any leaks in the fuel lines.
Thanks for any help.
