just re did : Batt1 cranking, positive 4.6 volts +/- , negative 1.2 volts +/- . Batt 2 cranking , positive 4.6 volts =/- , negative 1.2 volts +/- . there wer several non engagements of the solenoid , which has gotten worse throughout testing this afternoon and evening , probably from lack of voltage . In the morning ,I'm going to try and visually isolate the positive cables at the switch . I just can't see them through the wiring mess in the console. I was able to physically grab them at the switch to clean them , but wasn't able to follow them with any certainty. Thanks again to everyone , I didn't think I'd have another 5 page + thread !
f150 won't start on just 1 battery
in looking back over everything I've done so far , I may have another separate issue as it concerns the switch wiring. I don't think it will affect the issue I'm having but I believe there is one accessory wired to a battery post on the switch , as opposed to the field/common terminal . I will change that tomorrow . I have the bilge pump wired directly to a battery , bypassing the switch , not that it's a big issue as my boat is on a lift.
Originally posted by gsdanno1 View Postjust re did : Batt1 cranking, positive 4.6 volts +/- , negative 1.2 volts +/- . Batt 2 cranking , positive 4.6 volts =/- , negative 1.2 volts +/- . there wer several non engagements of the solenoid , which has gotten worse throughout testing this afternoon and evening , probably from lack of voltage . In the morning ,I'm going to try and visually isolate the positive cables at the switch . I just can't see them through the wiring mess in the console. I was able to physically grab them at the switch to clean them , but wasn't able to follow them with any certainty. Thanks again to everyone , I didn't think I'd have another 5 page + thread !
Load testing the batteries was mentioned before to make sure they are good may be a very good idea.
Cells/batteries do go badLast edited by 99yam40; 03-21-2017, 11:04 PM.
they were load tested in October , boat hasn't run since then , batteries were on charger when n all the balancer work was being done. as much cranking as I've done on it today , they wouldn't be able to recover as quickly as they have been , especially 1 , as that was the one I cranked the most. Additionally , this problem has been plaguing me since the last set of batteries , thought I had it sorted by cleaning the terminals at the power posts , but obviously not. Going to recheck the cables on the power posts tomorrow and wire wheel them to make sure I didn't forget those this morning
Your voltages reported, at going thru your system is bad.
RodBolt mentioned using the starter as a load tester(which I do as well). That NORMALLY works fine BUT YOUR current set up/ISSUE is NOT good for doing that test. So in your case, NO, it's NOT "that simple".
*I asked earlier about running a known good battery to the engine(by pass EVERYTHING) and see what happens.. NO RESPONSE, I gather not done.
I'd clean up that mess of spaghetti wiring as well, that may be drawing down / killing your batteries over time..
You'll be chasing your tail for quite awhile unfortunately...Scott
I will repeat myself , at the risk of being crude.
you have a load tester.
it is called a starter.
use it.
hook the meter leads to the + and - terminals.
crank it.
should not drop below 11v.
if that passes do a drop test on the batt leads.
the hull wireing is irrevalent.
Originally posted by rodbolt17 View PostI will repeat myself , at the risk of being crude.
use it.
crank it.
He's going thru the broken system so he will be chasing his tail..
If the hull wiring / accessory is draining his "good" battery as he won't check it, it certainly will kill / ruin a battery...Scott
Where the batteries fully charged when you did the test?
Are you sure that the readings where Volts and not Millivolts?
My advice would be to charge the batteries fully and carry out the voltage drop test again, yes again. Test got to be done correctly or the results are going to be invalid.
Also as another member suggested several times, take a set of boOster cables and known good battery, disconnect the boat wiring from the starter and hook up the battery directly to starter. If it turns over normally on the single battery then you know your starter is NOT the trouble. Can you do this?
Originally posted by gsdanno1 View PostI ll try that , don't know if I'll have enough cable to go directly to the battery
Danno, what Boscoe showed is what we've been trying to get you to do for a while, now. That's a "voltage drop test" for the cable. As mentioned before, do some homework if you don't understand and google it. It's OK if you don't understand, but do some research to help out! This is now a 76-post thread that should have been 10.
To extend your meter's wire, just use a 16g piece of electrical wire (not a corroded one!) from the meter lead end to the starter or battery. Lamp wire is fine. If you don't have any, you can buy it very cheaply by the foot. Extra alligator clips help with this.2000 Yamaha OX66 250HP SX250TXRY 61AX103847T
Originally posted by gsdanno1 View PostI did that , posted results in post 46 , it dropped to 10.4-10.8 volts
That is why RB and I asked to do a load test between the battery and the starter motor. Direct.
NOT thru 20' of unk cable, connections, switches, etc.
Pull the battery out of the console, bring it back to the engine (make sure it's fully charged before anything else).
Now positive on battery to the starter terminal (ground hooked up) and NOW CHECK the voltages... If the battery is good, the drop should be minimal and the engine SHOULD spin over normally..Scott
ÂÂÂÂÂ
