I switched the leads on the tester , and continuity reading was 0.000 . I had everything hooked up per the service manual. Test leads to the 2 big studs on the solenoid, battery positive to brown/white wire from solenoid , then just touched the starter body to engage bendix . I'd send a pic but I just unhooked everything and mounted starter on boat . Same issue as before , and there's racoon poop on board !
f150 won't start on just 1 battery
Originally posted by gsdanno1 View PostI switched the leads on the tester , and continuity reading was 0.000 . I had everything hooked up per the service manual. Test leads to the 2 big studs on the solenoid, battery positive to brown/white wire from solenoid , then just touched the starter body to engage bendix . I'd send a pic but I just unhooked everything and mounted starter on boat . Same issue as before , and there's racoon poop on board !
at least that is the way I think it should work.
never looked at a starter on a a f150-Last edited by 99yam40; 03-27-2017, 02:53 PM.
Originally posted by gsdanno1 View Poststarter passed all the voltmeter tests EXCEPT the magnet switch , which is what everyone calls the solenoid. It showed 0.011 when I did the test which involved hooking jumper cables to positive brown/white wire and then ground to starter body . Volt meter leads connected to the 2 lugs on the solenoid. I would have thought starter would have spun freely , but it just kicks out the starter gear . If this is enough evidence to buy a solenoid , that's what I'll do
But because there was NO power hooked to the Positive lug (one of the big lugs) then no power to turn the starter was available.
You had your meter hooked to the two main lugs and you where measuring ohms, correct? So you got 0.011 ohms resistance?
Originally posted by gsdanno1 View PostGround was to starter housing per service manual. I reversed leads on the voltmeter and had 0.000 . Everything I've read says position of the leads is immaterial
I asked you two questions:
-Was your "METER" set to Ohms when you preformed the test laid out in the service manual? Yes or NO (I suspect it was, but need to be sure)
- The picture I posted has nothing to do with that test, I just wanted to know if you got your starter to turn over on the bench, as hooked up in the picture? If you hooked it up to a battery like that then it should work. If not then we may be getting somewhere!
If you can kindly answer these two questions it may help.
in reply to Panasonic , no , I was just checking for continuity , so as I've found out , the starter won't turn over when hooked up the way I had it. my meter has a separate setting for continuity , I have had it in both ohms , and the continuity mode , get the same result - Continuity . I'll hook up and see if starter will spin , but I don't see why it wouldn't , since it will spin just fine with the battery switch in the "both" position
As I expected , starter spins just fine on battery cables with no load on it . EVERY test I have done on this thing has " passed" , I even went from bar to bar on the commutator , also had no problem , showed continuity all the way around. The only thing I am questioning is if I did the continuity test on the brushes correctly. I believe Yamaha says to check for continuity BETWEEN brush 1 and 2 , so I touched one lead on the brush marked 1 , the other on the brush marked 2 and read open , as per the manual
ÂÂ
