I have a 1991 Yamaha 150 ProV with the Yamaha 703 Shifter with the Choke Switch separate from the ignition switch. I need a new ignition switch for the 703.
Yamaha 703 Shifter Ignition Switch
Here you go.
703-82510-33-00 MAIN SWITCH ASSY $90.70
Overview
Description
Purchase this Yamaha 703-82510-33-00 MAIN SWITCH ASSY
Item 48 would be my best guess.
1991 P150TLRP Yamaha Outboard REMOTE CONTROL COMP - PARTS Diagram and Parts
The -10-00 has been superceded by the -18-00.
703-82510-18-00 MAIN SWITCH ASSY
Thanks for the info everyone. I would like to convert the 703 to a push to coke switch, but I have no clue on how to do that. I think it just needs a new switch. I don't even know how to check to see if it is the switch. So far when I am on dry land and run the boat it starts up and shuts off just fine, but out on the water it starts up but doesn't shut off with the switch or kill switch. Any suggestions on what might be the problem?
The white wire has no power. It is either grounded to the block or it is not. When the CDI is grounded via the white wire the motor stops running. Or should.Originally posted by rcfawjr93 View PostI am now thinking it is the CDI Unit. I checked the solid white wire going into the cdi unit and when i cut the switch off there was no power on that wire, but the engine kept running. Any Thoughts?
Is the white wire at the CDI connector (engine harness side) grounded when the key switch is turned off or the kill switch is activated? If so, carefully inspect the terminal on the other side of the connector. The CDI side if you will. Failure of a ground to reach the CDI because of corrosion within a connector can cause the problem you are experiencing.
Why are you checking for power? Power as in electrical power? As in 12 volts?Originally posted by rcfawjr93 View PostYes it is grounded. I checked on either side of the plug. The white wire shows to have no power when I turn the switch off but it keeps running.
The white wire does not ever have voltage (power) on it. It is either connected to ground or it is not connected to ground.
Remove the white wire from the CDI connector. Start and run the motor. Jumper the white wire terminal from the CDI to the block. An unpainted portion of the block. If the motor does not stop you need a new CDI.
